QoS on softphones
I have some computers that have Nortel i2050 softphones installed on them. the computers are connected to different 2950 switches with EI with the capability to support Autoqos for cisco-softphones.There is also a nortel Call manager application installed on one of the port of one of the switches.
Can somebody tell me the right way of enabling QoS inthis environment.
I am thinking this way,
1.enable auto qos voip cisco-softphone on all the switchports that are connected to the PCs running the soft-phones and the Call Manager.
2.enable auto qos voip trust on the switchport that connects to the PABX device.
somebody please help !!!!!!!!!
2.Enable
1 REPLY
Anonymous
N/A
Re: QoS on softphones
On the Catalyst fixed configuration switches, you can configure QoS by issuing automatic QoS commands or by issuing standard QoS commands. To use many QoS features, you must have the Enhanced Image (EI) installed on your switch.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_22_ea2/configuration/guide/swqos.html
428
