Community Member
QoS over Bridged WAN Link
Is there any working Config?
I have G.SHDSL router both sides
I want to apply policy map to ATM interface
Following is my config
policy-map WAN-EDGE
class Voice
priority percent 33
class Call-Signaling
bandwidth percent 5
class class-default
fair-queue
policy-map SHAPE-WAN-EDGE-128
class class-default
shape average 128000
service-policy WAN-EDGE
interface ATM0.1 point-to-point
ip address 1.1.8.2 255.255.255.252
no snmp trap link-status
atm route-bridged ip
pvc 0/35
protocol ip 1.1.8.1 broadcast
encapsulation aal5snap
Router(config)#interface ATM0.1 point-to-point
Router(config-subif)# ip address 1.1.8.2 255.255.255.252
Router(config-subif)# no snmp trap link-status
Router(config-subif)# atm route-bridged ip
DENIZLI(config-subif)#service-policy output WAN-EDGE
CBWFQ : Not supported on subinterfaces
Router(config-subif)#service-policy output SHAPE-WAN-EDGE-128
GTS : Not supported on this interface
Router(config-subif)#pvc 0/35
Router(config-if-atm-vc)#service-policy output WAN-EDGE
Router(config-if-atm-vc)#service-policy output SHAPE-WAN-EDGE-128
Router#sh policy-map interface
Router#
Hall of Fame Super Gold
Re: QoS over Bridged WAN Link
Try
pvc 0/35
cbr 2000 (or whatever the line speed is)
Community Member
I checked from Feature Navigator
Following features seems to be NOT-SUPPORTED for 878 G.SHDSL
Class Based Weighted Fair Queuing (CBWFQ)
Routed Bridge Encapsulation with ATM Virtual Circuit Bundles
Is there any other way?
CBWFQ is not what you're doing (MQC)
You are not using VC bundles.
Configure a explicit traffic paramenters as indicated above and let us know.
Community Member
I am using
(C870-ADVIPSERVICESK9-M), Version 12.4(15)T4, RELEASE SOFTWARE (fc2)
I apply following commands
Router(config)#interface ATM0.100 point-to-point
Router(config-subif)# ip address 1.1.2.2 255.255.255.252
Router(config-subif)# pvc 0/35
Router(config-if-atm-vc)# encapsulation aal5snap
Router(config-if-atm-vc)# service-policy output WAN-EDGE
Router(config-if-atm-vc)#cbr 128
The commands does not output any error
But I cannot see "-policy output WAN-EDGE" command from running-config.
Router#sh running-config
class-map match-any Call-Signaling
match ip dscp cs3
match ip dscp af31
class-map match-all Voice
match ip dscp ef
policy-map WAN-EDGE
class Voice
priority percent 33
compress header ip rtp
bandwidth percent 5
class class-default
fair-queue
class class-default
bridge irb
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
mtu 1500
no ip address
no atm ilmi-keepalive
pvc 0/35
cbr 128
That is not normal, you can try another image otherwise I recommend you engage TAC on the matter. Anyway since it's a poin to point circuit, why don't you use regual aal5mux encap for maximum efficiency.
Also, ip rtp compress and bridge IRB are not doing anything for you.
248
