Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
QoS witch a "Non-Cisco-IP-Phone" on a TRUNK-Port
we have "Non-Cisco-IP-Phones" with Cat3560+PoE and TRUNK-Ports with 2 Vlans(one DATAvlan,one VOICEvlan)
how is it possible to enable QoS (1st step: Classification and Marking) on this TRUNK-Ports with "service-policy input" (with class-map,policy-map)
it seem so, as it doesn't work on a TRUNK ?
there are no matches in ACL (sh access-lists) and POLICY-MAP (sh policy-map interface fastEthernet 0/1)
....any idea....
regards,
Ralf
Anonymous
N/A
Re: QoS witch a "Non-Cisco-IP-Phone" on a TRUNK-Port
Here is the link to the full configuration document:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swqos.htm#wp1231446
This command will tell the switch to trust whatever QoS values it recieves on the port and map it to the correct queue.
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 1 2 4
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 46
mls qos srr-queue output dscp-map queue 2 threshold 1 16 18 20 22 25 32 34 36
mls qos srr-queue output dscp-map queue 2 threshold 1 38
mls qos srr-queue output dscp-map queue 2 threshold 2 24 26
mls qos srr-queue output dscp-map queue 2 threshold 3 48 56
mls qos srr-queue output dscp-map queue 3 threshold 3 0
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 3 10 12 14
mls qos queue-set output 1 threshold 2 70 80 100 100
mls qos queue-set output 1 threshold 4 40 100 100 100
mls qos
class-map match-all voip-class
match access-group name voip-ports
policy-map voip-policy
class voip-class
set dscp ef
ip access-list extended voip-ports
permit udp any range 6004 7039 any
permit udp any any eq 5667
permit udp any any eq 5006
permit tcp any any eq 5666
permit udp any any range 6004 7039
permit udp any eq 5667 any
permit tcp any eq 5666 any
permit udp any eq 5006 any
end
edit your ports, im sure my ports wont match up with yours.
on your interfaces, you have to enable the priority queueing and bandwidth percentage:
interface GigabitEthernet0/1
switchport mode trunk
service-policy input voice
srr-queue bandwidth share 1 70 25 5
srr-queue bandwidth shape 3 0 0 0
priority-queue out
queues 2,3,4 get 70% 25% and 5% respectively.
queue 1 gets 33% of all available bandwidth.
Allen,
attached is my topology. The IP phones are placed on the access switches.
All access switches are 2960 and the L3 is 3750.
Where should i mark the traffic, on the 2960 or the 3560 and do i need to apply the service policy input to all the ports?
Attached diagram
323
