QOS with a BW or internet access shared between routers?
adelbano
Hello all.
I have a router in my internet access but this share the connection with other routers.
My question about BW is that if I want to configure QOS and shaping,,, what BW I need to use?
I don't understand where can I found BW used in a interface.
Thanks for your help gurus!!!
3 Accepted Solutions
acampbell
On any interface you will see the usage over the last 5 minutes by default
Example on my switch (Routers are the same)
show int fas 1/0/48
FastEthernet1/0/48 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 0017.9562.6534 (bia 0017.9562.6534)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4000 bits/sec, 6 packets/sec
  5 minute output rate 3000 bits/sec, 4 packets/sec
     58554591 packets input, 5635281796 bytes, 0 no buffer
     Received 40480113 broadcasts (39305055 multicasts)
     0 watchdog, 39305062 multicast, 0 pause input
Alex
Regards, Alex. Please rate useful posts.
This will show the input/output usage for the last 5 mins
You can tweek this down to the last 30 seconds
conf t
int fas 1/0/48
load-interval 30
show int fas 1/0/48
  30 second input rate 4000 bits/sec, 6 packets/sec
  30 second output rate 2000 bits/sec, 4 packets/sec
     58572904 packets input, 5636786364 bytes, 0 no buffer
     Received 40493710 broadcasts (39318211 multicasts)
     0 runts, 0 giants, 0 throttles ........
Alex
Albert,
You are welcome
Yes you are correct with your figures
You can also look at the loading figures on the interface but
you need to use your maths
     reliability 255/255, txload 206/255, rxload 67/255
  Keepalive set (10 sec).......................
So TX load is 206/255 = 206 X 100/255 = 80. 78 %
     RX load is 67/255 = 67 x 100/255 =  26.27 %
Alex
5 Replies 5
acampbell
show int fas 1/0/48
Alex
And this is the current interface BW? With this number can I calculate the average of the interface BW?
4kbps is the current BW?
conf t
int fas 1/0/48
load-interval 30
show int fas 1/0/48
Alex
Thank you for your answer.
And if it's a fasthernet link and the output tell there are 5Mbps, the link is 5/100=1/20=5% of the link used?
Tell me this last issue and I will understand all!!!
Thank you!
Albert.
Albert,
You are welcome
Alex
