12-13-2011 04:18 AM - edited 03-16-2019 08:31 AM
Hello all.
I have a router in my internet access but this share the connection with other routers.
My question about BW is that if I want to configure QOS and shaping,,, what BW I need to use?
I don't understand where can I found BW used in a interface.
Thanks for your help gurus!!!
Solved! Go to Solution.
12-13-2011 04:31 AM
On any interface you will see the usage over the last 5 minutes by default
Example on my switch (Routers are the same)
show int fas 1/0/48
FastEthernet1/0/48 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0017.9562.6534 (bia 0017.9562.6534)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4000 bits/sec, 6 packets/sec
5 minute output rate 3000 bits/sec, 4 packets/sec
58554591 packets input, 5635281796 bytes, 0 no buffer
Received 40480113 broadcasts (39305055 multicasts)
0 watchdog, 39305062 multicast, 0 pause input
Alex
12-13-2011 05:12 AM
This will show the input/output usage for the last 5 mins
You can tweek this down to the last 30 seconds
conf t
int fas 1/0/48
load-interval 30
show int fas 1/0/48
30 second input rate 4000 bits/sec, 6 packets/sec
30 second output rate 2000 bits/sec, 4 packets/sec
58572904 packets input, 5636786364 bytes, 0 no buffer
Received 40493710 broadcasts (39318211 multicasts)
0 runts, 0 giants, 0 throttles ........
Alex
12-13-2011 06:28 AM
Albert,
You are welcome
Yes you are correct with your figures
You can also look at the loading figures on the interface but
you need to use your maths
reliability 255/255, txload 206/255, rxload 67/255
Keepalive set (10 sec).......................
So TX load is 206/255 = 206 X 100/255 = 80. 78 %
RX load is 67/255 = 67 x 100/255 = 26.27 %
Alex
12-13-2011 04:31 AM
show int fas 1/0/48
Alex
12-13-2011 04:46 AM
And this is the current interface BW? With this number can I calculate the average of the interface BW?
4kbps is the current BW?
12-13-2011 05:12 AM
conf t
int fas 1/0/48
load-interval 30
show int fas 1/0/48
Alex
12-13-2011 06:07 AM
Thank you for your answer.
And if it's a fasthernet link and the output tell there are 5Mbps, the link is 5/100=1/20=5% of the link used?
Tell me this last issue and I will understand all!!!
Thank you!
Albert.
12-13-2011 06:28 AM
Albert,
You are welcome
Alex
