qsic trunk between ccme and nec pbx
tkavithas87
hi,
i need to configure qsic trunk between ccme and pbx.i want the configuration for qsic on ccme.does any one have the configuration?how the dialpeer should be configured?
paolo bevilacqua
Wrong forum, post in "voice - IP telephony". You can move your post using the actions panel on the rignt.
thanks paola for the information
I have looked through the Cisco Interoperability Portal
This link is as near to what config you need as I can find
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns829/625258.pdf
You may need you look at changes like E1 for T1 etc
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
thanks alex.it is helpful.
