QSIG and transfer - calling side drops
Hi all
I have a problem to transfer incoming calls from the PSTN to an IP Phone. Here it is:
1) I call from PSTN to my IP Phone:::: OK
2) On the IP Phone, I transfer the call to another IP phone. I wait until this third party answers the call then I hit "Transfer" again and the call is transferred :::: OK
The problem :
1) I call from PSTN to my IP Phone :::: OK
2) On the IP Phone, I transfer the call to another IP phone, but this time I just dial the destination number and press the "Transfer" while receiving the ringback. On my PSTN phone I hear the ringback but once the call is answered, the call drops .
It only happens with my ISDN QSIG link to the PSTN. If I try this calling to a line connected on a FXO, it works just fine.
Is there any addictional parameter to be configured on the gateway ??
Regards !
Rodrigo
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: QSIG and transfer - calling side drops
Hi Rodrigo,
What you are seeing is the CCM default for Transfer with QSIG. By default CCM supports Consultive Transfer (your scenario number 1) and not Blind Transfer (your scenario number 2). Have a look;
Call Transfer - QSIG
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803edb19.html#wp1139777
Cisco CallManager supports call transfer by join only.
When a user transfers a call to another user, the QSIG identification service changes the connected name and number that displays on the transferred party phone. Call identification restrictions can impact what displays on the phone.
The call transfer supplementary service interacts with the path replacement feature to optimize the trunk connections when a call transfers to a caller in another PINX. For more information about path replacement, see
Path Replacement
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803edb19.html#wp1156114
Hope this helps!
Rob
Hi Rodrigo,
Path Replacement
Hope this helps!
Rob
Hello Rob
Thanks for your great help !
Let me just ask you one more thing. According to the "Path replacement" document, I understand that the exact reason why CM does not support blind transfer is ...
(from the second document you sent )
"Path Replacement
Note: Cisco CallManager provides "requesting" and "cooperating" PINX messages only. If configured for QSIG, Cisco CallManager responds to third-party vendor PINX "inviting" messages, although Cisco CallManager will not originate "inviting" messages."
Is it right ?
Thanks in advance,
Rodrigo
Hi Rodrigo,
First off, you are most welcome. And you are right on the money here :)
Hope this helps!
Rob
Hall of Fame Super Gold
Wait a moment. connection to PSTN, in my experience, is never QSIG. Any type of appropriate ISDN switch, yes. But not QSIG.
So please configure the correct switch-type and try again.
Hello Bevilacqua
Here in Brazil is pretty common to have QSIG signaling to the PSTN. This deployment is an example of this. The carrier established this protocol for us.
Thank you !
Rodrigo
Ok. In any case, collect debug isdq 931 if you see strange behavior again. It will tell exactly what is being doing in protocol if the GW can decode the qsig.
236
