Community Member
QSIG Error PRI5033
I am getting a QSIG error "PRI5033" I am running CM 6.1 . ANyone seen this or have any ideas?
Re: QSIG Error PRI5033
The error means An application has requested to send on a QSIG a non-call related message
received on MCDN but the QSIG RCAP is not configured on the outgoing link or
the service is not supported on QSIG. The message is rejected.
Output: DCH or DSL number, PRI/BRIT type, Service identifier.
Service Identifier data 4 is defined as Network Message Center.
What are you trying to do when this message is generated?
Community Member
We are not doing anything, There is no traffic on the pri. I took the "qmwi" off the "d" channel and the message has gone away.
Community Member
I removed the qmwi from the RCAP def on the 'd' channel and all is okay now.
279
