QSIG trunk with Nortel Meridian
I need to integrate CUCM 6.0 with Nortel CS1000M for my client. I put an MGCP gateway and configured QSIG trunk
beteween CUCM and PBX. The connectivity is like this
CUCM --> MGCP --> QSIG --> PBX
Now the calls are working both ways from IP Phones at CUCM to POTS phones at PBX and vice versa. Caller ID and
Caller Name are going from PBX to CUCM. But NOT from CUCM to PBX. The client is taking care of their PBX configuration,
they use QSIG variant (IFC:ESIGX ESGF) at PBX. I am using default QSIG configuration on CUCM. i.e. ISO QSIG E1.
I have already enabled the commmands " isdn outgoing ie facility" at the gateway. Below are the some commands enabled at the gateway.
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no logging event link-status
isdn switch-type primary-qsig
isdn timer T310 120000
isdn protocol-emulate network
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn outgoing ie extended-facility
isdn outgoing display-ie
isdn outgoing ie connected-number
isdn outgoing ie caller-number
isdn outgoing ie caller-subaddr
isdn outgoing ie called-number
no cdp enable
Can anyone confirms the configuration and shed some light if my above configuration and signalling are compatible. I also see a QSIG variant ECMA in service perimeter at CUCM but dont know if its compatible.
I dont know anything about Nortel configuration. Is it possible that incoming CLID and Caller Name is not enabled at Nortel PBX for incoming calls.
Thanks in advance.
Green
Re: QSIG trunk with Nortel Meridian
Could you please try to play with those parameters in CUCM side:
ASN.1 ROSE OID Encoding
QSIG Variant
Also paste debug isdn q931 for 2 calls, incoming from PBX and another from CUCM to PBX.
Please find the debug result below from both ways.
PBX to CUCM
*Sep 15 04:57:45.030: ISDN Se0/0/1:15 Q931: RX <- SETUP pd = 8 callref = 0x2600
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x91AA068001008201008B0100A11C0202010006042B0C09008010554E494649454420434F4D4D20494244
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0980, '6600'
Plan:Private, Type:Unknown
Called Party Number i = 0x89, '1102'
Sending Complete
Locking Shift to Codeset 5
Codeset 5 IE 0x31 i = 0x80
Codeset 5 IE 0x32 i = 0x81
*Sep 15 04:57:45.054: ISDN Se0/0/1:15 Q931: TX -> CALL_PROC pd = 8 callref = 0xA600
*Sep 15 04:57:45.054: ISDN Se0/0/1:15 Q931: TX -> ALERTING pd = 8 callref = 0xA600
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Sep 15 04:58:23.906: ISDN Se0/0/1:15 Q931: TX -> CONNECT pd = 8 callref = 0xA600
Facility i = 0x91AA06800100820100A11102010206042B0C09028006557365722032
Connected Number i = 0x0083, '1102'
*Sep 15 04:58:23.942: ISDN Se0/0/1:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x2600
CUCM to PBX
2821-GW#
*Sep 15 04:59:35.402: ISDN Se0/0/1:15 Q931: TX -> SETUP pd = 8 callref = 0x0003
Sending Complete
Standard = CCITT
Facility i = 0x91AA06800100820100A11102010006042B0C09008006557365722032
Calling Party Number i = 0x0181, '1102'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x80, '6600'
Plan:Unknown, Type:Unknown
*Sep 15 04:59:35.530: ISDN Se0/0/1:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8003
*Sep 15 04:59:35.542: ISDN Se0/0/1:15 Q931: RX <- ALERTING pd = 8 callref = 0x8003
Facility i = 0x91AA068001008201008B0100A11C0202010006042B0C09018010554E494649454420434F4D4D204942
*Sep 15 04:59:42.114: ISDN Se0/0/1:15 Q931: RX <- CONNECT pd = 8 callref = 0x8003
Facility i = 0x91AA068001008201008B0100A11C0202010006042B0C09028010554E494649454420434F4D4D204942
Progress Ind i = 0x8182 - Destination address is non-ISDN
Connected Number i = 0x0080, '6600'
*Sep 15 04:59:42.118: ISDN Se0/0/1:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0003
Any idea
Green
Which service parameter is configured in CUCM
From PBX we are getting 0x91 is
ECMA (Protocol Profile 0x91)
Also from CUCM...we are sending ECMA
This link is form other PBX but mentions parameters describe above if you change them any luck?
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00803d22cd.shtml
Yes, it was set to ECMA at service parameters.
I changed it to service parameter
ISO (Protocol Profile 0x9F)
Use Local Value.
The result is the same. Anything else i can check out there. Also, is everything configured correctly at Gateway?
Resolved.
Cli was not enabled at Nortel Extension.
Thanks for all the help.
Hi sfurgani
I have the same problem here, do you have the commands you put on the nortel PABX to enable CLI?
regards
solomon
970
