Qt: Cisco ip phone serivices Authentication URL response
Hello
I wrote a program with Qt to work with cisco ip phone services. I'm using QNetworkAccessManager to post XML objects to phones and QTcpServer's socket with QTextStream to respond to authentication requests (simply writing http headers with "AUTHORIZED" to text stream). The code:
QString cTime = currTime.currentDateTimeUtc().toString("ddd, dd MMM yyyy hh:mm:ss");
QTextStream os(socket); os << "HTTP/1.1 200 OK\r\n"
"Content-Type: text/plain\r\n"
"Date: " + cTime + " GMT\r\n"
"Connection: close\r\n"
"\r\n"
"AUTHORIZED";
The problem is the phones don't accept that response and return <CiscoIPPhoneError Number="4" />.
I used node.js for that before and simply wrote "AUTHORIZED" to http.serverResponse object, but I'm confused now why it doesn't work with Qt
Everyone's tags (3)
1 ACCEPTED SOLUTION
You might want to ask this on
You might want to ask this on the developer forum
java
if this helps, please rate
www.cisco.com/go/pdi
java
Solved that.The problem was
Solved that.
The problem was the "Secure Authentication URL" field was set along with "Authentication url". And what I thought to be GET from phone was "Client hello"...
Cleared "Secure Authentication URL" in CUCM and it works now
308
