Que Status Softkey?
Running CUCM 9.1 and documentations says Que status can be monitored via a PLK on select models.
How do you set a PLK on a 7911?  I have not seemed to find a Softkey that says Que status either.
Am I missing something?
Kevin
Que Status Softkey?
PLK is not a softkey
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/9_0_1/ccmfeat/CUCM_BK_CEF0C471_00_cucm-features-and-services-guide_chapter_0111.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Que Status Softkey?
Thanks for your respose. I know PLK is not a sofkey but in some discussions and documentation is states you can configure a softkey as a Que Status and I have not seen that option anywhere. wondering what I am missing or if I am miss informed.
Kevin
Hall of Fame Super Red
Que Status Softkey?
Hi Kevin,
HLOG is supported on both Softkey & PLK but Queue Status is "only"
supported on PLK;
Queue Status PLK
Queue status PLK is only supported with the following LCD display phones for both SCCP and SIP protocols:
  • 6921
  • 6941
  • 6945
  • 6961
  • 7911 G = wrong info
  • 7931 G
  • 7942 G
  • 7945 G
  • 7962 G
  • 7965 G
  • 7975 G
  • 8961
  • 8945
  • 8941
  • 9951
  • 9971
HLOG PLK
You  must configure phones that support hunt group logging in or out through  HLOG softkey or PLK. If a phone does not support HLOG softkey or PLK,  line members cannot log in from their phone.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/9_1_1/ccmfeat/CUCM_BK_C3E0EFA0_00_cucm-features-services-guide-91_chapter_01000.html
The problem with this document is that 7911's don't support PLK's as they are single line
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
354
