Query regarding CME Extension mobility configuration
swati-singh
Hi team,
From what I have read in the "voice user-profile" configuration we give number <dn> type <ring-type>. The dn here is the extension number. My doubt here is if different ephone-dns have the same number, how can we distinguish them.
Multiple ephone-dn can have same number. "user profile" configuration is asking for only the number. How can we tell which ephone-dn it belongs to. Basically, if we want to use the call hunt feature (using preference and huntstop commands), where same number will be used by different ephone-dns and differerent ephone-dns with same number should be assigned to users so that the call rings on 1 user phone after the other (instead of all phones at same time which happens if all numbers belong to same ephone-dn), how can I achive with user-profile/extension mobility configuration.
Swati
swati-singh
Could you please help me here. Please let me know if the question is not clear.
Swati
Hi Swati,
If you run the Show run command it will display the eintire congif on the CME.
ephone x is mapped to specific MAC ids of the phones and also with specific buttons, and than later on you will map the ephone-dn x to a specific number (Directory Number).
As shown below.
c3825(config) #ephone 1
      c3825(config-ephone) #mac-address 000D.BDB7.AE4A
      c3825(config-ephone) #type 7960
      c3825(config-ephone) #button 1:1
      c3825(config-ephone) #exit
      c3825(config) #ephone-dn 1
      c3825(config-ephone-dn) #dual-line
      c3825(config-ephone-dn) #number 2222 1
      c3825(config-ephone-dn) #allow watch
      c3825(config-ephone-dn) #exit
You need to do a reverse check here. From Number to ephone-dn and than to button and than to phone MAC.
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answer !!
Hi Anand,
But, my question is: When the same Number is used by multiple ephone-dns, to which ephone-dn should I map the number?
I am asking about the Extension mobility configuration:
voice user-profile 4
user addepall password 1234
number 50004 type normal
and both ephone-dn 111 ans 112 use the same number
ephone-dn  111  octo-line
number 50004
ephone-dn-template 1
ephone-dn  112  octo-line
number 50004
How should I mention in the user-profile configuration that the number 50004 is dn 111 and not 112? In extension mobility, phones/mac addresses will not have any button configuration. Users should login to their profile to get their buttons.
Swati
