Querying CDR Database
I am running CUCM 7.1.3 and I am wanting to write my own web application that will let me query data from the CDR database. I keep finding resources that show on the older systems (when they ran Windows) you would just connect to the sql server and query. I fear that it's not so simple these days and there is a different method of doing so. My guess is some kind of SOAP or XML call ?
Thank you!
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: Querying CDR Database
UCM will FTP flat files of the CDR records to a server of your choosing. It's up to your application to parse them and load the records into SQL.
Cisco Unified Serviceability Administration Guide, Release 8.0(2) - CDR Repository Manager
Cisco Unified Communications Manager Call Detail Records Administration Guide, Release 8.0(2)
Please remember to rate helpful responses and identify helpful or
You can also qry directly the DB
CDRonDemand SOAP Service
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/devguide/8_0_1/serviceability.html#wp1058811
Programming Guides
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_programming_reference_guides_list.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
VIP Super Bronze
Programming Guides
java
java
Thank you for the excellent replies as usual. I stumbled upon the cisco developer portion of the website yesterday after I asked but I figured a push in the right direction couldn't hurt.
Do you know if there are any open source products that connect and do (even basic) CDR querying?
Also, if I am reading right, you make a SOAP request and you end up downloading a file from it with the results? Logic (i think?) would tell me that it would be returned in the SOAP reply, right? I haven't used it as much as I should.
Again, thank you both.
609
