[Question] 4.1.3 SR7 MGCP/QSig Hicom
Hi all,
we have a QSIG Link between Frankfurt and London and use a HiPath 4000 in Frankfurt and a Call Manager Cluster running 4.1.3 in London.
If someone calls from Frankfurt the full international number for the London Extension is displayed whilst it rings but as soon as it's answered it defaults back to our London 5 Digit Extension.
I have traved it and from the call manager we only get a Connected Number i = 0x0081 with the 5 digit extension.
If the call is made the other way around everything is fine.
TRACE (1st Fra->LON ):
Sep 16 17:32:16.906: ISDN Se1/4:15 Q931: RX <- SETUP pd = 8 callref = 0x007B
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98392
Exclusive, Channel 18
Facility i = 0x9FAA068001008201008B0100A10F020221910201553006820406400840
Facility i = 0x9FAA068001008201008B0100A11C020221A0020100A113040E42414945522C205354454646454E020101
Calling Party Number i = 0x1183, '496971367138'
Plan:ISDN, Type:International
Called Party Number i = 0x91, '4420747589'
High Layer Compat i = 0x9181
Sep 16 17:32:16.910: ISDN Se1/4:15 Q931: TX -> SETUP_ACK pd = 8 callref = 0x807B
Sep 16 17:32:17.070: ISDN Se1/4:15 Q931: RX <- INFORMATION pd = 8 callref = 0x007B
Called Party Number i = 0x91, '9'
Sep 16 17:32:17.198: ISDN Se1/4:15 Q931: RX <- INFORMATION pd = 8 callref = 0x007B
Sep 16 17:32:17.218: ISDN Se1/4:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x807B
ukgre00-110-cm1#
Sep 16 17:32:17.218: ISDN Se1/4:15 Q931: TX -> ALERTING pd = 8 callref = 0x807B
Facility i = 0x9FAA06800100820100A115020101020101800D5374656666656E204261696572
Progress Ind i = 0x8088 - In-band info or appropriate now available
Sep 16 17:32:18.182: ISDN Se1/4:15 Q931: TX -> CONNECT pd = 8 callref = 0x807B
Facility i = 0x9FAA06800100820100A115020102020102800D5374656666656E204261696572
Connected Number i = 0x0081, '58999'
ukgre00-110-cm1#
Sep 16 17:32:18.274: ISDN Se1/4:15 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x007B
ukgre00-110-cm1#
Sep 16 17:32:26.778: ISDN Se1/4:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x807B
Cause i = 0x8090 - Normal call clearing
Sep 16 17:32:26.894: ISDN Se1/4:15 Q931: RX <- RELEASE pd = 8 callref = 0x007B
Sep 16 17:32:26.902: ISDN Se1/4:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x807B
ukgre00-110-cm1#****connected number call frankfurt london ***
Anyone?
THX
Steff
1 REPLY
Re: [Question] 4.1.3 SR7 MGCP/QSig Hicom
2nd 2nd Lon->Fra:
ukgre00-110-cm1#
Sep 16 17:32:47.082: ISDN Se1/4:15 Q931: TX -> SETUP pd = 8 callref = 0x0AA6
Sending Complete
Standard = CCITT
Channel ID i = 0xA9839E
Exclusive, Channel 30
Facility i = 0x9FAA06800100820100A115020101020100800D5374656666656E204261696572
Calling Party Number i = 0x1181, '442074758999'
Called Party Number i = 0x91, '496971367138'
Sep 16 17:32:47.186: ISDN Se1/4:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8AA6
ukgre00-110-cm1#
Sep 16 17:32:47.842: ISDN Se1/4:15 Q931: RX <- ALERTING pd = 8 callref = 0x8AA6
Facility i = 0x9FAA068001008201008B0100A10F0202238F02015530068204061C0840
Facility i = 0x9FAA068001008201008B0100A11C0202239E020101A113040E42414945522C205354454646454E020101
ukgre00-110-cm1#
Sep 16 17:32:49.086: ISDN Se1/4:15 Q931: RX <- CONNECT pd = 8 callref = 0x8AA6
Facility i = 0x9FAA068001008201008B0100A10F020223DA02015530068204061C0840
Facility i = 0x9FAA068001008201008B0100A11C020223E9020102A113040E42414945522C205354454646454E020101
Connected Number i = 0x1180, '496971367138'
Sep 16 17:32:49.090: ISDN Se1/4:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x0AA6
ukgre00-110-cm1#
Sep 16 17:32:53.871: ISDN Se1/4:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8AA6
Sep 16 17:32:53.883: ISDN Se1/4:15 Q931: TX -> RELEASE pd = 8 callref = 0x0AA6
Sep 16 17:32:54.111: ISDN Se1/4:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8AA6
ukgre00-110-cm1#****connected number call london farnkfurt***
117
