Question about CAR and CDR Load in CUCM 6
Can I stop CDR Load if I don't use CAR as service, but I use CDR with external server that collects CDR files from CUCM? What checkbox should I check and what should I remain?
Re: Question about CAR and CDR Load in CUCM 6
Here is screenshot
Any answer?
not sure if i understand, but you can try. cdr enabled in CM under system,service param param, callmanager active. but if you disable, in anyway, i dont think you have output for cdr server.
hth
Am I clearly explained?
I want to stop some loading on CAR, but I want
to remain CDR functionality.
My questions:
1)Can I check checkbox Disable Loader on the screenshot? Should CDR functionality remain working?
2) What should I do to minimize CAR functinality on CUCM? Just reply - CDR as loading files on external server should remain.
Thanks!
Hall of Fame Super Red
Hi Alexandr,
1)Can I check checkbox Disable Loader on the screenshot? **Yes
Should CDR functionality remain working? **Yes
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/car/carsysch.html
Hope this helps!
Rob
What steps can you advice me to stop CAR service?
P.s. there are CAR Web service in CUCM, in CAR page, etc
Hi Alexandr,
Procedure
Step 1 Choose Tools > Service Activation.
The Service Activation window displays.
Step 2 Go to the Servers drop-down list box.
Cisco Unified Communications Manager
Choose the first node of the cluster server name.
Cisco Unified Communications Manager Business Edition
Choose the server name.
The window displays the service names for the server that you chose, the service type, and the activation status of the services.
Step 3 Check the check boxes next to the following CDR Services:
•Cisco SOAP-CDRonDemand Service (optional). If you are using a third-party billing application that accesses CDR data via an HTTPS/SOAP interface, activate this service.
•Cisco CAR Web Service
Tip Unchecking the check boxes next to the CDR Services and clicking Update deactivates the services. If you deactivate the Cisco CAR Web Service, the system removes CAR from the Tools menu in Cisco Unified Serviceability.
Step 4 After you have finished making the appropriate changes, click Update.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_0_1/car/caranrpt.html#wpxref97735
Hope this helps!
Rob
Any answer?
368
