Question about CUCM 8.5
Hi Folks & Friends,
I have tricky requirement you to answer for my corporate.
Consider i have 2 CISCO IP Phone DN as below.
Phone 1 : 1001
Phone 2 : 2001
Both configured for different locations in my CUCM. and both DN doesnt have voicemail facility.
Here my requirement :
  • If any one call to Phone 1 after 3 rings it should forward the call to Phone 2 and on phone 2 it should ring 3 times then the call should disconnect.
  • If any one call to Phone 2 after 3 rings it should forward the call to Phone 1 and on phone 1 it should ring 3 times then the call should disconnect
In call manage i have enabled the forward settings on both the phones ( i.e Phone 2 will forward the call to Phone 1 and the Phone 1 will forward the call to Phone 2 after 3 rings )
But what is happening here is call is getting loop and also it is not getting disconnect. How can we change this behaviour.
          Your answers are highly appreciated...   Kulasekara Raja. K
  • IP Telephony
Everyone's tags (4)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
phone A DN - 1101
phone B DN - 2101
Hunt Pilot A DN - 1001
Hunt Pilot B DN - 2001
Line Group A membership:
Phone A DN 1101
Phone B DN 2101
routing top-down
Line Group B membership:
Phone B DN 2101
Phone A DN 1101
routing top-down
Hunt Pilot A --> hunt list A --> Line Group A
Hunt Pilot B --> hunt list B --> Line Group B
Hunt Pilots defined to hunt for 24 seconds (assuming US cadence of 4 sec ring cycles)
Line Groups defined to hunt for 12 seconds
HTH,
Chris
I'd configure a line group for each set of DNs and use the 2 DNs as the hunt pilots as well, do not configure a CFB/CFNA behavior
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Java,
Thank you for your reply...
I have configured a line group from Call Routing --> Route/Hunt --> Line Group.
The values as follows:
Line Group Name : Test_Group, RNA reservation timeout : 3, Distribution Algarithum : Top Down.
In the current line group members it shows 1001 and 2001
Hope i have configured it correctly. But when i give ring to 1001 it rings always it is not going to 2001.
Correct me if i did any mistake in the configuration part. Since i am totally new for this domain.... :-(
Kulasekara Raja. K
You need to change the DNs of the phons and build 1001 and 2001 as DNs of the hunt pilots.
HTH,
Chris
Hi Chris,
Thank you very much for your time and reply...
If you dont mind could you please explain briefly how your plan will satisfy my requirement.
Kulasekarar Raja. K
phone A DN - 1101
phone B DN - 2101
Phone A DN 1101
Phone B DN 2101
routing top-down
Phone B DN 2101
Phone A DN 1101
routing top-down
HTH,
Chris
Hi Chris,
Thank you very much for your brief explanation on this.
Will try and let you know the result.
Cheers !
Kulasekara Raja. K
647
