$$ Question about Gatekeeper$$
Hello all,
I want to ask about, I have a gatekeeper and i make 2 zones each zone contain 3 gateways,and this gateways are used for voice, my question is, Can I assign different tech-prefix to each gateway at the same zone? or each gateway will has the same tech-prefix?
Thanks a lot.
1 ACCEPTED SOLUTION
Re: $$ Question about Gatekeeper$$
You can register different gateways within a zone with different tech prefixes using the "h323-gateway voip tech-prefix" interface configuration command on the gateway. So you could have:
Gateway 1
fas0/0
h323-gateway voip tech-prefix 2#
Gateway 2
fas0/0
h323-gateway voip tech-prefix 3#
Hope this helps.
Brandon
plz i need help
Gateway 1
fas0/0
Gateway 2
fas0/0
Hope this helps.
Brandon
Thanks a lot Eng.Brandon
103
