question about integrating Gatekeeper and CUCM
Hi all
How to integrate CUCM with Gatekeeper?
I have a simple lab enviroment: a CUCM 2XXX, a gatekeeper and a CME router with 7...
Configuration on Gatekeeper:
gatekeeper
zone local voiceie labnet.com 1.1.1.1               CUCM zone
zone local cmeie labnet.com  1.1.1.1               CME zone
zone prefix voiceie 2...
no shutdown
show gatekeeper end:
                    GATEKEEPER ENDPOINT REGISTRATION
CallSignalAddr  Port  RASSignalAddr   Port  Zone Name         Type    Flags
2.2.2.2         1720  2.2.2.2         58610 cmeie             VOIP-GW
    H323-ID: CME
    E164-ID: 7001
    E164-ID: 7002
    Voice Capacity Max.=  Avail.=  Current.= 0
143.3.64.11     34042 143.3.64.11     32785 voiceie           VOIP-GW
    H323-ID: Trunk-1_1
Total number of active registrations = 2
on CME
1, configure to register with Gatekeeper
2, create voip dial-peer 134 route 2... to Gatekeeper
Try to call from Phone 7001 in CME zone to phone 2001 in CUCM failed.
debuge dial-peer  in CME shows:
Jan 25 14:20:46.633: //-1/9B29990F8039/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=134
Jan 25 14:20:46.669: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2..., Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_ANSWER; Calling Number=2...
Jan 25 14:20:46.669: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
Jan 25 14:20:46.669: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=, Expanded String=, Calling Number=2...T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
Debuge dial-peer  in Gatekeeper
Jan 25 14:20:46.655: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=2001
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Jan 25 14:20:46.655: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Is any thing wrong here?  thanks in advance.   Roy
1 REPLY
If is CUCM dont forget to configure the trunks to the GK take a look on this guide.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b06gatkp.html
341
