question about upgrade CUCM
The procedure to upgrade a CUCM is install de upgrade package in the cucm, and after it make the swtich version from inactive version to active, but, question is if I have already a inactive version installed, if upload the new version will overwrite the previous version?
Thanks.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Correct, only one version can be present in inactive partition, so if you are doing a second upgrade the original version will be gone as the first upgrade version will be moved to inactive partition.
HTH,
Chris
HTH,
Chris
ok thanks!
105
