09-12-2013 09:12 AM - edited 03-16-2019 07:20 PM
I am in the process of deploying some 9971 phones. I have run into a problem where there appears to be a wiring problem on a particular cable run. The phone keeps trying to boot and connect to the network but never completes the process. If I move the phone to another outlet, it works just fine. I have swapped out the patch cables at the desk end and the wiring close end of the cable run. This tells me that the problem is in the rj45 jacks at one of the cable or the other. I ran the tdr diagnostic commands and I am showing an open pair (pair D). Is there a way I can get the switch to route power over one of the other pairs ?
If not, i am looking at a process of several weeks to get the wiring group involved to fix the problem because that has been outsourced to an outside organization.
Ron
09-12-2013 09:30 AM
No, you will need to solve the wiring issue or deploy 9971 wirelessly in that area.
HTH,
Chris
09-12-2013 09:48 AM
ronald do one thing.......its for sure it will work
juz log in that switchport.....and do speed auto 100m
connect the 1236 only ...that is orange white to orange white....
orange to orange...
green white to green
and green to green
after doing 100m 9971 is working on 4 wire(A and B pair only )....will work
plz rate if found helpful
09-12-2013 09:55 AM
Sure you can do that as 100Mb does not use other pairs, but you would be downgrading the speed to the PC connected to the phone 100Mb, in any case might work for you if you are OK with it, assuming that wires 4,5,7,8 are the broken ones.
HTH,
Chris
09-12-2013 10:03 AM
100mbps is not a small speed sir.......u will use video call or watever its a local lan speed....i tried no issue of freezing and all if u use 100m....still if u want to use 1000m u can but all pair is needed as it becomes gig device.....
u can directly connect 9971 on switch with a patch cord sir
Please rate if its helpful
09-12-2013 10:04 AM
as u are saying ur D pair is open.....then juz change the wire simple
09-12-2013 10:10 AM
I disagree, 100Mb is obviously a lot more bandwidth a phone would ever need, but if you have a PC connected to the phone on a 1Gig network then the phone becomes a bottleneck. If the user only uses the PC for browsing and email it is not a problem, but if he/she needs large file transfers for example of blueprints, images, etc then they would not be happy losing their speed.
Chris
09-12-2013 10:13 AM
yeeah chris i agree..........but if u r finding that wid tdr test D pair is open why dont u chage d cable sir...as u don wanted to chage the cable i suggested dis...........so that u can bypass D pair can run same fone with the same cable
jz make it 100m and see whether it gets registered or not...for a check
Rate plz if its helful
09-12-2013 10:16 AM
What's up with all this abbreviated writing, really hard to make it out. Are you texting?
Chris
09-12-2013 10:23 AM
hahahhahhaa dont mind........sorry
I meant to say juz go to the switch port and make the speed 100m if your phone works ....means it was a cable issue
Rate if its helpful
09-12-2013 03:47 PM
If Pair "D", which controls GigabitEthernet, is faulty, then it's as simple as configuring the port to negotiate to 10/100 Mbps.
09-16-2013 06:49 AM
Thanks for all the replies. In addition to the tests I had run, I also tried a new phone just to make sure I didnt have something squirly there. The new phone showed the same problems.
I brought in my old faithful Fluke Enterprise Lanmeter 683. It didnt see any problems. Being that old it doesnt have the ability to test at 1GB. Based on the the posts in this thread, I locked the port down to 100MB/Full Duplex and the phone comes up as expected.
I want to find a docuement or something that explains the difference in wire use or something that I can take to my boss to help explain this. Without something like that, he will never believe me.
Thanks for all the help,
Ron
09-16-2013 06:52 AM
See table "802.3af Standards A and B" as it should make it clear.
http://en.wikipedia.org/wiki/Power_over_Ethernet
HTH, please rate all useful posts!
Chris
09-16-2013 07:21 AM
1,2, 3 and 6 are for carrying data.. and 4,5,7,8 for power over ethernet..
STANDARD | SOURCE | COMMENTS | |||||||
Ethernet RJ-45 connector pin number | |||||||||
1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | ||
IEEE 802.3af | RX DC+ | RX DC+ | TX DC- | spare | spare | TX DC- | spare | spare | Industry Standard for Embedded POE (used by Cisco Catalyst Switches) |
IEEE 802.3af | RX | RX | TX | DC+ | DC+ | TX | DC- | DC- | Industry Standard for Embedded POE |
Cisco | RX | RX | TX | DC- | DC- | TX | DC+ | DC+ | Older Cisco Products (polarity is reversed) |
Cisco | RX | RX | TX | DC+ | DC+ | TX | DC- | DC- | IEEE Compliant |
dear Nutter.........hope it will somehw work
please rate if u find my posts helpful
