07-23-2013 11:59 AM - edited 03-16-2019 06:30 PM
My Call Manager Express only has Config files for the 79XX series of telepbones. How can I get the necessary files to be able to use Cisco 6921?
Also, since I don't already have the files in my system, will I have to purchase these from Cisco?
07-23-2013 06:28 PM
Whats your CME version?
07-24-2013 06:13 AM
Thanks for your response Jaime, the version is 12.4.
thanks again.
07-24-2013 06:34 AM
You need to upgrade to a version which supports 6921s
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
