Question on Attendant console
I have UCM 6.1.2. We have two receptionist that want to be able to share the incoming call load. And at night the calls go to voice mail when they log out. I setup for the call distribution to be top down and go to phone A line 1, phone B line 1, Phone A line2 and so on, with the last object being a port that forwards to the night greeting. The problem is that phone A gets all the calls first, only if she is on the phone does it go to phone B, which is how it is designed. However they are not too keen on that design. If I change the distribution to Most Idle, the voice mail port will pick up every now and then. I tried to set the Call Forwarding up on the hunt pilot but that did not seem to work. So either I am doing something wrong or is there a better way to set this up.
Ken
1 ACCEPTED SOLUTION
Re: Question on Attendant console
You can do this with linked hunt groups. Create three hunt groups; call them Main, AB, and BA. Configure then as such:
Hunt Group AB - First Available
Receptionist A's #1
Receptionist B's #1
Receptionist A's #2
Receptionist B's #2
Voice Mail
Hunt Group BA - First Available
Receptionist B's #1
Receptionist A's #1
Receptionist B's #2
Receptionist A's #2
Voice Mail
Hunt Group Main - Circular
Pilot # for Hunt Group AB
Pilot # for Hunt Group BA
Receptionist A's #1
Receptionist B's #1
Receptionist A's #2
Receptionist B's #2
Voice Mail
Receptionist B's #1
Receptionist A's #1
Receptionist B's #2
Receptionist A's #2
Voice Mail
Chris,
Good Idea. Thanks for the input. I will try that.
Ken
123
