Bronze
Question on changing NTP servers with VMware CUCM 8.6
HI all,
If you change the NTP server references in CUCM OS Configuration > System > NTP Server References, will that force you to re-host the licenses for CUCM?  The UI itself doesn't give me the feeling that would be the case, but I know changing the DNS servers would force that, so I'm a bit paranoid about it.
Thanks!
/p
Yes, if you change the primary NTP server value then you will need to rehost the license.  See the following for details/confirmation:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/virtual/servers.html#wp86411
There is a 30 day grace period after changing any of the License MAC values.
Hailey
Please rate helpful posts!
Bronze
Thank you for confirming and the source link.  Much appreciated.
1386
