Question on CUE
I inherited a 2800 ISR with an AIM-CUE installed. When I execute the command: show software versions from the CUE console I get the following:
"Session closed"
I don't work with CUE often, but I am pretty sure the above output is a problem.
Any thoughts?
-Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Everyone's tags (1)
1 REPLY
Question on CUE
Hi Bill,
Try this command
show software licenses
show software packages
if you still get "Session closed" then try call to voicemail
if you cannot get to voicemail, I suggest you hardware reset the AIM-CUE module
Power on or power off, reinsert the module, and make sure the module and the ISR router are tight
connected.
Or for some Unity version, It take longer time for to load.
The IOS boot first, but Unity are still loading for my UC 500, IOS 15.1
________________________________________________________
Health Unity Express
CCME#service-module in 0/0 status
Service Module is Cisco Integrated-Service-Engine0/0
Service Module supports session via TTY line 2
Service Module is in Steady state
Service Module heartbeat-reset is enabled
Getting status from the Service Module, please wait..
Cisco Unity Express 8.0.6
CUE is on UC500UC500
Unity Express being shutdown in progress
Service Module is being Shutdown
CCME#
Service module in slot 0 shutting down in 105 seconds...
After Unity Express showdown
Service Module is trying to recover from error
Service Module status is not available
____________________________________________________________
Reload Unity Express
That is my experience with UC 500, hope this help, thanks.
Henry
309
