Bronze
Question on dial-peer matching for SIP calls based on From URI
I have the need to match a dial-peer based on the IP address of the provider sending us a call.  I read this doc
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_i1.html#wp1113316
Which indicates that we should create a uri voice class and add the host of the service provider, then use the incoming uri command on the dial peer to match the class.
So I ahve
voice class uri 80909 sip
host ipv4:<IP in "from" header from the ITSP>
dial-peer voice 510 voip
description <removed>
preference 1
session protocol sipv2
session target ipv4:<removed>
incoming uri from 80909
voice-class codec 1
voice-class sip early-offer forced
voice-class sip options-keepalive
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
But the calls still 404.  If I add a destination pattern, the calls match perfectly.
Running IOS 15.1(4)M3 on a Cisco 3825 router.
When I debug ccsip messages, I do see the IP I want to match in the From header
Received:
INVITE sip:<removed>@<IP of the 3825>:5060 SIP/2.0
Via: SIP/2.0/UDP <IP of the ITSP we're trying to match>:5060;branch=z9hG4bK1sansay3287000127rdb8746
Record-Route: <sip:sansay3287000127rdb8746@IP of ITSP:5060;lr;transport=udp>
To: <sip:<removed>@<IP of the 3825>>
From: <sip:<removed>@<IP of the ITSP>>;tag=sansay3287000127rdb8746
Call-ID: 984000968-0-2130291236@<removed>
CSeq: 1 INVITE
Contact: <sip:<removed>@IP of the ITSP>:5060>
Cisco-Guid: 3794994627-250470193-3196230199-3910696620
Supported: timer,100rel
Session-Expires: 36000;refresher=uac
Min-SE: 90
P-Asserted-Identity: <sip:<removed>@<removed>>
Remote-Party-ID: <sip:<removed>@<removed>>;party=calling
Expires: 300
h323-conf-id: 3794994627-250470193-3196230199-3910696620
Content-disposition: session
User-Agent: Sippy
Max-Forwards: 69
Content-Type: application/sdp
Content-Length: 299
v=0
o=Sansay-VSXi 188 1 IN IP4 <IP of the ITSP>
s=Session Controller
c=IN IP4 <IP of the ITSP>
t=0 0
m=audio 27042 RTP/AVP 0 8 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
a=maxptime:20
Jan 14 13:01:03.516 est: //4087257/E23305C3BE82/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP <IP of the ITSP>:5060;branch=z9hG4bK1sansay3287000127rdb8746
Date: Tue, 14 Jan 2014 18:01:03 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Sent:
SIP/2.0 404 Not Found
To: <sip:<removed>@<IP of the 3825>>;tag=D5FA05A8-CF4
CSeq: 1 INVITE
Reason: Q.850;cause=1
Content-Length: 0
Bronze
Hi Paul,
You want to match inbound or outgoing dial peer on the basis of IP address in from field? voice-class uri command can be used to match a dial peer in Inbound direction only. As per your configuration dial peer 510 will be matched in Inbound direction then on the basis of called number outgoing dial peer will be matched. Here it looks like outbound dial peer is not found by router due to which call failed with 404 not found. Could you provide below mentioned debugs with calling and called number
debug ccsip message
debug ccsip error
debug voip ccapi inout
Also provide me "show run".
Mohit Singh
Bronze
Hi Mohit,
I ended up opening a case with TAC.  I'll post the results once they help sort out what's going wrong here.
Did you ever get this
Did you ever get this resolved?  I think I am looking to do something similar.  I want to set my session target based on the incoming URI.
333
