Bronze
Question on switch-version and data loss
In reading info around the web, I do find and understand that any changes made to configuration of an upgraded CUCM node will be lost if they were made after upgrade but before switch-version.  I was wondering if CDR files/database were also grouped into this, or if those are copied over when switch-version is executed.
1 ACCEPTED SOLUTION
Hi,CDR records will be lost,
CDR records will be lost, only user facing features are preserved. Please check the following post
https://supportforums.cisco.com/discussion/11117171/cucm-upgrade-and-cdr-records#3293654
Manish
Manish
Bronze
Thanks Manish.  Do you know
Thanks Manish.  Do you know if there's a similar write-up for Unity Connection?  I already know UCCX loses everything, based on experience.
Please check the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrugx/8xcucrug015.html
Manish
Bronze
Wow, that's a lengthy read.
Wow, that's a lengthy read.  Tnanks for the pointer, I'll have to set aside some time to process through that one.
100
