09-01-2014 04:37 AM - edited 03-16-2019 11:58 PM
We have a production CUCM cluster running 8.6.
I have been asked to create 300-400 translation patterns.
I see that I can not do that directly via BAT. But I see import/export option.
We already have 1000s of existing translation patterns on our system.
I have a quick question about the import feature.
Does a new import replace the existing data in the database with the data in the import file or does the new data in the import file get added to the existing data.
if the import file has only the new translation patterns, will it wipe out the existing translation patterns in the system?
I don't have a lab cucm system to check this behaviour?
Can you please help me on this query?
Pete
Solved! Go to Solution.
09-01-2014 07:46 AM
I do this often and it is the only way to bulk add translation patterns. It will not remove any translation patterns it will only add/change the translation pattern. If all new patterns it will simply add your new entries.
09-01-2014 07:46 AM
09-01-2014 08:51 PM
Thanks a lot for the very helpful reply, Mike.
-Pete
