Questions about C220 / C240 TRC
Previously in the C200 and C210 world, there is a single SKU configuration used for UC
- ucs-c200m2-vcd2
- ucs-c210m2-vcd2
I was wondering - are there similar SKUs for the C220 / C240?
Also, for a BE6k, if I want hardware redundancy, do I just order another UCSC-C220-M3SBE with a VMW license R-VMW-UC-FND5-K9?
Thanks.
-Dave
1 REPLY
Since you're with a partner you can get in touch with PH for those questions:
www.cisco.com/go/ph
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
464
