questions about PRI voice on UC520
I will be setting up my first PRI in a couple of days and figured I need to do some homework before I jump in. Below I have the config that I want to start off with and a couple of questions: Thanks in advance.
1) Based on the config below, do I need any more commands to bring up the circuit?
2) I asked my provider to provision for NI Version 2 but I don't seem to have that option when configuring the circuit. Should I ask them to reprovision to NI Version 1?
3) I figure that at some point in the bring-up of the circuit the telco tech will claim that "everything is fine on my end, must be your end". What are some good debug or show commands that will help to troubleshoot the circuit if it doesn't come up?
card type t1 0 3
network-clock-participate wic 3
network-clock-select 1 T1 0/3/0
isdn switch-type primary-ni
controller T1 0/3/0
framing esf
linecode b8zs
pri-group timeslots 1-24
interface Serial0/3/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
voice-port 0/3/0:23
VIP Super Bronze
Re: questions about PRI voice on UC520
One thing I learnt from my senior friend here Paolo, is to use the loopback command on your controller...This way you can authoritatively inform the telco that your end is fine..to use the loopback command do the following:
1. conf t
2. controller t1 0/3/0
3.loopback local line
Exit the config mode and type sh controller t1 0/3/0, you should see up up and looped.
Coommon and most helpful commands used to troubleshoot isdn setup are
1. debug isdn q.921 ..if your layer 2 is not coming up, this will help you to see message exchanges between your t1 card and the telco switch
2. Use show isdn status, to see the status of your isdn cirtcuit, this will show layer1 to layer 3 status..ideally if evrything is good, you should see multiple frame established..similar to this
ksh1f-intr3825#sh isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial1/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
1 Active Layer 3 Call(s)
CCB:callid=479A, sapi=0, ces=0, B-chan=1, calltype=VOICE
Active dsl 0 CCBs = 1
The Free Channel Mask: 0x80007FFE
Number of L2 Discards = 0, L2 Session ID = 4
Total Allocated ISDN CCBs = 1
ksh1f-intr3825#
3. You can use a show controller t1 0/3/0 to see if there are any alarms on your circuit..The type of alarm will tell you where the problem is.
Attached is a glossary of isdn alarms and what they mean.
4. You might need to add this command under your
isdn bchan-number-order ascending.
This is used to avoid a term called glare condition..basically this happen when your telco and router select channels in same order.
5. ALso on your pots dial-peer you will need to add
progress_ind alert enable 8
eg dial-p 1 voice pots
This will let your users hear phone ringing before the called party picksup.
This is all I can think of now...
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hello again. I brought the PRI up today and was able to make outbound calls quite easily. However inbound calls I cannot get to work. I did "debug isdn q931" and I can see the 10 digit inbound call. However I cannot get an ephone-dn to receive the call. My DNs currently look like this:
ephone-dn 91 dual-line
number 4085551212
label 408551212
description DID1
name DID
call-forward busy 200
call-forward noan 200 timeout 10
Any idea?
Diego
Hall of Fame Super Gold
it's a bit strange because when the number matches, phone must ring.
Anyway, configure a translation-profile and rule:
voice translation-rule 100
rule 1 /^40855511/ /2/
voice translation-profile makedid
translate called 100
voice-port x/y/z
translation-profile incoming makedid
and give you DN regular extension numbers like 2xx.
You should be ok then. The example is if you have 2 actual DID digits.
Don't know if it would have anything to do with this but I noticed that the PRI was provisioned for Natl ISDN 2. However I don't see a Natl ISDN 2 option for switch type. I have:
How do I know I am using Natl 2? I am able to make outgoing calls.
Diego
switch-type doesn't really matter, beside ni-1 and 2 are highly interoperable.
All what matter are the numbers. Get them right and everything works, a small mistake and nothing does.
Will do.
Diego
VIP Super Bronze
The attachments.
Attached are some good documents used for troubleshooting e1/t1 issues
Thanks guys. Those tips/docs look like they are going to help a lot.
Diego
301
