Community Member
questions about two phone numbers in one UC520
My boss has two companies registered under his name and the two companies are sharing same office. We have two phone numbers from comcast, and going into FXO-1 and FXO-2 ports. We want to use one number for each company. (number A for company A and number B for company B )My questions are:
1. when someone calls in, am I able to tell which number is being called? If so where to set up this feature? ( we want different greetings from our office manager for different companies.)
2. Am I able to choose the number between the two numbers as the call out number manually each time when I want to call out? (I.E. if I`m calling the customer of company A, then I want to choose number A, if I`m calling the customer of company B, then I want to choose number B)
I`m using CCA and I don`t see these features. I`m not familiar with CLI commands but if that`s available in CLI, please let me know how to do it.
Thank you very much!
1 REPLY
Re:questions about two phone numbers in one UC520
Hi peter,
Try to configure connection plar opx on both fxo ports and then test if it works.
Mudit
Sent from Cisco Technical Support Android App
Thanks & Regards, Mudit Mathur
130
