Questions about upgrading from CCM 6.1.4 to 8.0(3)
I have a few questions I want to confirm:
We have CCM 6.1(4) in our cluster that we will soon be upgraded to CCM 8.0(3a).
  1. First I want to install CCM 8.0(3a) into the inactive partition on all CCM servers without switching the version (or rebooting the server).  I will do the version switch on a seperate day.  Is that possible?
   2. I have the CCM 8.X software feature licence.  Do I need to install this license before I install CCM 8.0(3a) into the inactive partition or can I do that         before I do a "Switch Version"?
   3.  I'm assuming no additional licensing is needed for our device units right?
Thank you!
-rya
Everyone's tags (6)
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hey Rya,
Yes, you can upgrade into the inactive partition and do the switch-version at a later
time. You will need to track any changes that are made to the db between the upgrade time
and the switch-version to redo them after the final step
The 8.x Software feature license will be added after the switch-version is completed.
All node and DLU licenses will be migrated during the upgrade.
The upgrade from 6.1(4) to 8.0(3) is a direct upgrade path as shown;
Check out Table 8:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
Hey Rya,
Check out Table 8:
Cheers!
Rob
Thanks for the confirmation Rob!
-rya
217
