09-23-2013 04:25 AM - edited 03-16-2019 07:29 PM
Hi!
i am making a mock-up in CUCM9 testing the new queuing into hunt pilot.
This is the new window in this version for queuing:
Question is, how can i manage scripts in a CCX? in destination pattern put the extension of my CCX server? is the only way I see
Thanks!
Solved! Go to Solution.
09-23-2013 04:35 AM
UCCX scripts are totally different from the basic queuing functionality in CUCM9. If you want to roll calls over to UCCX, then you just need to put the extension of your UCCX Jtapi trigger in the destination
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
09-23-2013 04:35 AM
09-23-2013 04:55 AM
aaa ok, then instead of put my voicemail extension, put the jtapi triggerof CCX.
Thanks, just only need to test it, but my phones are unregistered due to license. Do you know if without a demo license in cucm 9 is not possible register any phone? I can not register even the CIPC.
(waiting for TAC , a problem with my license....)
Thanks!!
09-23-2013 04:58 AM
If you dont have a demo license, then you need a valid production license. Without any form of licenses, you will have issues with adding phones etc
09-23-2013 05:03 AM
ok thanks......this is what is happening........
regards!
