Silver
Quick help needed- Create an admin account
I need to create a temp account to access the OS in 5.x so to allow someone else to shut down the server and then I will delete it again afterwards- can you let me know- When I access it I always have to use the admin account many thanks
1 REPLY
Re: Quick help needed- Create an admin account
use this command:
set account
all the usage info is on the below link
Set Commands
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/5_1_1/iptpappa.html#wp1011080
javalenc
java
if this helps, please rate
www.cisco.com/go/pdi
128
