Bronze
Quick key or keys to force all to VM?
CM4.2.3sr1 is central topology in Calif and just migrate our Zurich,switzerland office into the mother ship. This office only has apprx 10 folks
They have 7940 with a Main Line and a personal line which hunts on Main.
After work, they have a feature on the old system whereby the main recept press a key and all the personal ext gets forward to Main Office VM. Can CM4.2.3sr1 do anything similar?
1 REPLY
Re: Quick key or keys to force all to VM?
you mean just 1 key press had all the extensions reach the Main Office VM??
if so we do not have any functionality like that, if it's time based you can use TOD for that purpose, whenever they're out of shift they will reach the main office VM. other option would be to configure a night bell and when they go home have them press CFA + night bell #
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
107
