Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Quick Question
Dear all,
I need your assistance to configure my VG224 to connect fax machine and to integrate to call manager 4.1
Your input is highly appreciated.
VIP Super Bronze
Re: Quick Question
Use sccp to configure the VG.
You need to configure this on the gateway and then you need to configure the gateway on CCM.
Check the VG documentation.
Sample sccp configuration below:
sccp local FastEthernet0/0
sccp ccm 10.123.160.10 identifier 10 priority 1
sccp ccm 10.185.88.14 identifier 11 priority 2
sccp
sccp ccm group 1
associate ccm 10 priority 1
associate ccm 11 priority 2
stcapp ccm-group 1
stcapp
dial-peer voice 10 pots
service stcapp
port 2/1
dial-peer voice 11 pots
service stcapp
port 2/2
dial-peer voice 9 pots
service stcapp
port 2/0
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Re: Quick Question
Thank you for your quick response. Do I need to configure anything in the voice port and dial-peer? let say in voice-port 2/0 and dial-peer voice 101 pots.
Please advice.
Regards.
110
