"answer-address" not working
I have 3 PRA circuits installed on one 3845 router. I want to send calls from certain numbers out to a specific PRA. Following the Cisco doc, I used answer-address command to match the calling number, then trigger a translation-profile that prefixes 2 digits to the called number. Then use a destination-pattern of the prefixed digits to route the call out a specific PRA.
The problem I am having is that 'answer-address' dial-peer is nerver matched, but a dial-peer 1 is used for incoming leg, and so a default PRA is selected.
As there is no wild card used in the answer-address command, is it the best match?
Relative configs are as follows. Please advise any errors I have made.
Thanks in advance.
voice translation-rule 771
rule 1 /^\([1-9].*\)/ /772\1/
voice translation-rule 772
rule 1 /^772/ /0/
voice translation-profile PSTN-Outgoing
translate called 772
voice translation-profile SIP-Incoming
translate called 771
dial-peer voice 10 pots
translation-profile outgoing outgoing-calls
service session
destination-pattern .T
direct-inward-dial
port 0/2/1:15
forward-digits all
dial-peer voice 9254300 pots
translation-profile outgoing PSTN-Outgoing
service session
destination-pattern 77T
direct-inward-dial
port 0/3/0:15
forward-digits all
dial-peer voice 9254311 voip
translation-profile incoming SIP-Incoming
service session
destination-pattern 99254311
notify redirect ip2pots
redirect ip2ip
session protocol sipv2
session target ipv4:A.B.C.D
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
fax protocol pass-through g711alaw
no vad
dial-peer voice 925431112 voip
answer-address 99254311
redirect ip2ip
dtmf-relay rtp-nte
codec g711ulaw
fax-relay sg3-to-g3
no vad
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: "answer-address" not working
DP 10 I guess ? These are the consequences of not seeing configs in full :(
Is the DN of the calling phone 99254311?
Brandon
Hi Brandon,
Yes. It is located off a 2811.
Thanks.
Seems fine. Can you shutdown DP 9254311 and enable "debug voip dialpeer", post result here.
Hi, here is the debug voip dialplan output. I am calling 21856588 from 99254311.
042315: May 16 09:18:44.057: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=6421856588, Called Number=6421856588, Peer Info Type=DIALPEER_INFO_SPEECH
042316: May 16 09:18:44.057: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Match Rule=DP_MATCH_DEST; Called Number=6421856588
042317: May 16 09:18:44.057: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
042318: May 16 09:18:44.057: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=10
042319: May 16 09:18:44.057: //-1/52927366882E/DPM/dpAssociateIncomingPeerCore:
Calling Number=99254311, Called Number=6421856588, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
042320: May 16 09:18:44.057: //-1/52927366882E/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
042321: May 16 09:18:44.061: //-1/52927366882E/DPM/dpMatchPeersCore:
Calling Number=, Called Number=6421856588, Peer Info Type=DIALPEER_INFO_SPEECH
042322: May 16 09:18:44.061: //-1/52927366882E/DPM/dpMatchPeersCore:
042323: May 16 09:18:44.061: //-1/52927366882E/DPM/dpMatchPeersCore:
042324: May 16 09:18:44.061: //-1/52927366882E/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=10
042325: May 16 09:18:48.616: Modify Nominator =
042326: May 16 09:18:48.616: FAX_TONE_DET
042327: May 16 09:18:48.616: MODEM_TONE_DET
042328: May 16 09:18:48.616: CM_TONE_DET
All possible debugging has been turned off
Cisco managed to change things again behind our back!
Please configure "dial-peer inbound selection sip-trunk". See:
http://www.cisco.com/en/US/docs/ios/12_3t/voice/command/reference/vrht_d1_ps5207_TSD_Products_Command_Reference_Chapter.html#wp1471437
Hi Paulo,
I am use version c3845-advipservicesk9-mz.124-4.T1.bin. It does not take the command.
I may need to upgrade the IOS.
For a test, can you switch to h.323 ?
Nothing in doc leads to think the "new" rules applies to that protocol too (supremely confusing).
Hi Paulo,
I got it. One DP has a 'incoming called-number .T' command that catches everything. I shutdown this DN and my DP starts working.
Thanks for your help.
You are right.
I also did a 'debug voip ccapi inout', which is attached.
367
