Community Member
"Detect Unified CM Connection Failure" global change
i'd like to ask a quick question: is it possible to change the parameter "Detect Unified CM Connection Failure" which is in "Product Specific Configuration Layout" component of Phone Configuration Page globally in a way that i do not have to change it manually in every affected phone one by one? I went through all objects like Device Pool etc. in CUCM to see whether it can be done this way but couldn't find.
Thank you in advance
Hall of Fame Super Silver
You can change it in "Common Phone Profile".
HTH,
Chris
Community Member
I checked it also on Common Phone Profile as well and there is "product specific configuration layout" part indeed but this parameter is still missing...at least in my case i cannot see this.
Would it be possible then that the only option is BAT for this bulk export,modify and import transaction?
Thanks for response
What version of CUCM are you running? I see it on 8.5.
Chris
Community Member
I have 8.0.3.22900-5 so it looks like that i'd have to upgrade CUCM to achieve that?
2879
