"Dial-peer cor list" command not working
I have a cisco 891 router having c890-universalk9-mz.152-4.M4.bin IOS,
Show version
voice-gw#sh ver
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 17:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(22r)YB3, RELEASE SOFTWARE (fc1)
multinet-voice-gw uptime is 2 weeks, 6 days, 21 hours, 59 minutes
System image file is "flash:c890-universalk9-mz.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 891 (MPC8300) processor (revision 1.0) with 498688K/25600K bytes of memory.
Processor board ID FCZ173992T4
9 FastEthernet interfaces
1 Gigabit Ethernet interface
1 Serial interface
1 terminal line
1 Virtual Private Network (VPN) Module
256K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO891-K9           FCZ173992T4
License Information for 'c890'
    License Level: advipservices   Type: Permanent
    Next reboot license Level: advipservices
i want to implement COR list but Dial-peer cor custom command is not working.
voice-gw(config)#dial-peer ?
  data        Data type
  hunt        Define the dial peer hunting choice
  inbound     Define the inbound options
  no-match    Define the disconnect cause for no dialpeer match
  outbound    Define the outbound options
  search      Define dial peer search service
  terminator  Define the address terminate character
  voice       Voice type
It doesnt show COR? what could be the reason?
thanks.
Silver
Global info about COR:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
I think your router doesn't support this...
HTH,
Dragan
HTH, Dragan
Thanks for your response. Is there any cisco document which says cisco 891 router doesnt support COR? I have checked IOS and it does support cor list commands.
Silver
The only best source - Cisco Feature navigator
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Check there to be sure 100%...
HTH,
Dragan
HTH, Dragan
Show dial-peer cor command works on same router but doesnt work on configuration mode ..strange!
voice-gw#sh dial-peer cor
Class of Restriction
voice-gw#
Problem solved after changing IOS, there might be bug in previous IOS and is not mention any where in cisco docs. after copying latest version c890-universalk9-mz.154-1.T1.bin, dial-peer cor command works!
Silver
Great!
Good info...
HTH,
Dragan
HTH, Dragan
118
