"host not found" IP phone 7940
allan.paula
Hi, i have one 2821 with ios c2800nm-ipvoicek9-mz.124-11.XW2.bin. Even with logout-profile and user-profile configuring, my 7940 show the message of "host not found". Not showing the option "Extension Mobility".
What could you help me?
testeven
Hi!
I guess you get that message when you press the "Services" button on the IP phone.
Please confirm that the services URL is on the phone if you go to Settings Button--> Network Config--> Services URL.
It should look something like:
http:///CCMCIP/authenticate.asp
Verify that you-ve enabled the
ip http server and url authentication url application-name commands.
Please check that you've followed all the configuration steps at:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html
HTH!
Tere.
Regards, Tere. If you find this post helpful, please rate! :)
testeven
Hi!
HTH!
Tere.
