"I didn't recognize that as a valid entry" when dialing directory number from outside
Hey all - I'm having an issue provisioning a phone for an employee and I cannot, for the life of me, figure out what the issue is. I have setup a 7941 for the user with an extension of 612. I am able to dial his number internally, I am able to dial out externally from his phone and dial from his phone to any number internally. The problem is when I call our office the attendant tells me that this is not a valid entry.
Has this happened to anyone before? I cannot figure out what the issue is....
I am Cisco Unified CM 8.5.1.13900-5
And who is the attendant?????
And who is the attendant????? and what is the call flow????
I would assume CUC from what you're saying, but you need to provide that information.
java
if this helps, please rate
www.cisco.com/go/pdi
Is there a mailbox with
Is there a mailbox with extension 612? By default Unity will not route to numbers if they do not have mailboxes.
180
