"Location" Parameter Calculator
Hi there,
Is there any calculator available to determine the Audio Bandwidth for a location?
Thanks.
1 ACCEPTED SOLUTION
Re: "Location" Parameter Calculator
u mean u have two locations that mean u have created two regions right?
what codec do u use between reagions?
if u use g711 then
512/80 about 6 calls
if g729 about 21 call
but if u use g711 bwith the site and g721 between locations in this case u will need a trnascoder!
just put 512 in the audio bandwidth
good luck
if helpful Rate
this is cisco bandwidth calculator for voice need registered useres
https://tools.cisco.com/Support/VBC/authc/forms/CDClogin.fcc?TYPE=33619969&REALMOID=06-000e3fb4-2d43-142b-95c5-83846dc90000&GUID=0&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$GDuJAbSsi7kExzQDRfPKUItt%2bPcjKOjTGlbtk%2fRp7BdNYLiP9lyOBjXBU5PAxIXD&TARGET=http%3A%2F%2Ftools.cisco.com%2FSupport%2FVBC%2Fjsp%2FCodec_Calc1.jsp
keep in mind the folowoing facts
each g711 call with location CAC in CCM need 80k while on IOS GK needs 128k
each g729 call with locations CAC in CCM needs 24k while with IOS GK needs 16k
good luck
if helpful Rate
Hi marwanshawi,
Thanks for your answer. I hope you can help me with this. If I have a 512 line, what should I choose in Audio Bandwidth field?
if u use g711 then
good luck
if helpful Rate
143
