You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
"Not enough bandwidth" Steps to Identify and resolve?
We are a non-profit healthcare with 12 locations. We have T1s to each location.
Some sites will get the above error message. I need to get a help hand in the steps to identify and resolve this big issue. When this happens it might happen for hours. Even afftects in-comming calls (we think).
Bill Branch
North Country HealthCare
Director of Information Technology
O: 928.774.8254
C: 928.607.9746
  • IP Telephony
Re: "Not enough bandwidth" Steps to Identify and resolve?
That message is related to the location BW you have allocated and it means it's exhausted.
Call admission control operates by rejecting a  call for bandwidth and policy reasons. When a call gets rejected due to  call admission control, the phone of the called party does not ring, and  the caller receives a busy tone. The caller also receives a message on  their phone, such as "Not enough bandwidth."
Call Admission Control
Above link explains how this works and how locations and regions play together for this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
What kind of Call Admission Control (CAC) mechanism do you have setup on CallManager ? If just Location BW values is used to do CAC, the 'Not Enough Bandwidth' means that either / both of the location(s) associated with the current call being made doesn't have enough BW to allow the call.
What version of CallManager are you running ? There have been some Location BW leaks in the past. During a scheduled maintenance window, you can browse to System > Locations, browse to each Location, and resync Bandwidth. You can start collecting detailed CCM traces (http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml#calm and https://supportforums.cisco.com/docs/DOC-8130) from the point of BW resync, and check if there is a location BW leak.
- Sriram
I am looking into those questions now...I will post them ASAP when I get them. Thanks for your slice of time!
Bill Branch
O: 928.774.8254
C: 928.607.9746
Bill,
Usually this message appears when there is not enough bandwidth configured/available between locations. The first thing I would do is to verify if it is correct.
Out of Bandwidth message means you have that phone in a Location in
CallManager and all bandwidth to that location is tied up (as far as
CallManager is concerned). Either:
1) Assign more bandwidth to that location under System -> Location
2) Go to Device - Phone, look up user's phone and remove the location (set
to ),
3) Configure AAR to re-route via the PSTN
Workaround:
Another way to do this would be to use the Locations feature in CallManager.
It's in the System menu in CCMAdmin. When there is not enough bandwidth left
between locations, then the phone will display "Not Enough Bandwidth" and
they will be required to manually dial the number again through another
path.
Here's the SRND for CUCM 7.x for your future reference:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/uc7_0.html
If you really want the details on it, the best it to get the Cisco Callmanager logs, and post it. I can try to have a look at it.
Nick
Seriously helpful! I will have some logs when time permits. Unbelieveably helpful!
Bill Branch
O: 928.774.8254
C: 928.607.9746
Are there specific names to these logs?
Bill Branch
O: 928.774.8254
C: 928.607.9746
Could you just confirm that you have increased the bandwidth? Which version of CUCM do you use?
Nick
BW has not been upgraded
...same T1s...or are you asking any change in WAN BW throughout the network? Yes, but not to the affected sites
The logs are "Cisco Callmanager service" at the arbitrary level.
It contains SDI and SDL logs.
4080
