Community Member
"One monent please your call is being connected" message
Here is a weird message I am now getting when I dial a fax machine 4 digit extension or 7 digit number.
Where is this coming from? IPCC? How could I tell?
Randall
Re: "One monent please your call is being connected" message
what is the call flow of this??
is that a female or male voice??
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
Community Member
it is a female voice. it has to be internal to the CCM 4.1.3 since it happens when I dial only 4 digits.
Not sure of the call flow. How do i look at that?
Rnadall
you would need to look at your dial plan to find out what elements you're matching, even if it's only 4 digits you could be reaching something else (unity, IPCC)
javalenc
java
Silver
It sounds like Unity, in the users subscriber options there is a tick box regarding transfer annoucement turning it off / on
try turning that option off and test, maybe you're right and it's the unity lady. that's why i asked for the call flow
javalenc
java
158
