02-28-2008 12:20 AM - edited 03-15-2019 09:07 AM
I am not able to view the history as well as the active calls if i use "show isdn active" command on the router 3845.
Need help.
Hemant
03-05-2008 06:46 AM
This is a follow up on your problem please try this bug CSCec82109 - Show Isdn Active not showing output
03-05-2008 07:09 AM
03-05-2008 05:15 PM
Are you using MGCP on your gateway and perhaps ISDN L2/L3 backhauling?
I noticed also there was no "show isdn active call" etc etc type output when using isdn backhaul under MGCP.
03-06-2008 12:33 AM
Yes, I am using backhauling using MGCP....backhauling to CCM.....
03-06-2008 03:50 PM
Yeah, as I thought.
It seems that you do not get any "show isdn xx" output when your backhualing ISDN L2/L3 to CCM via MGCP.
Certain "show isdn active/history" commands state: "%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply"
I'm guessing most likely because the CCM is controlling the D channel on the ISDN the gateway doesn't get to see much of it from a ISDN L3 perspective, probably because the CCM has its CDR's with which to track calls.
03-07-2008 05:30 AM
Yeah...this could be the reason that sh isdn active/history does not show any output...
Thanks a lot for help...
