11-02-2009 04:43 AM - edited 03-15-2019 08:19 PM
Hi all,
I have to change this value from "false" to "true" for about 75 phones in my environment.
Is there a way to do that without touching and resetting every phone by hand?
I just had a look to bulk administration , but it seems as if there is no way to change this field.
Has anyone a hint or idee on this problem?
greetings
Chris
Solved! Go to Solution.
11-11-2009 03:59 AM
Look at Phones > Update Phones. The Excel spreadsheet does not contain every setting available!
You use a Phone Template when adding phones initially to set these things. The spreadsheet contains the values that unique to each phone (MAC, description, Owner User ID, etc) and the Phone Template sets everything else.
11-02-2009 05:14 PM
Hi Chris,
what version of CUCM are you running? the "Span to PC" field is available in BAT from at least version 6.0.1
regards,
Paul
11-03-2009 12:42 AM
Sorry I forgot: it's a 6.1.3 :-) maybe I looked at the wrong menu-point.
greetings
Chris
11-11-2009 03:22 AM
So,
just a small negative update.
I just had a look at the BAT spreadsheet (phones->create file format).
No possibility to set the"span to pc" field to enabled or disabled.
11-11-2009 03:59 AM
11-11-2009 04:04 AM
Wow thank you very much!!! That was a point I didn't watch.
I always look for the phones in general or the BAT.
greetings
Chris
