"splat" at end of moh file
Guys,
I have an srst router playing a moh file. at the end of the file when played there is a "splat" sound. when you play a copy of the file from a pc before you load it, this sound is not there. Also, another file on the router does not make this sound. is it in the incorrect format? if so what is the best approach to getting it right?
Garry
1 REPLY
Hall of Fame Super Red
Re: "splat" at end of moh file
Hi Garry,
It certainly could be the file format, here is some reference material;
Format:
Average Data Rate 8.0 kb/second
Sample Rate 8.0 Khz
Audi Sample Size 8.0 Bit
Channels 1 (Mono)
Integrating Cisco CallManager and Cisco SRST to Use Cisco SRST As a Multicast MOH Resource
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html
Hope this helps!
Rob
239
