03-24-2008 03:01 PM - edited 03-15-2019 09:37 AM
I need to raise our Domain functional level to 2003, but my boss is concerned how this may affect our phone sytem.
We are running Call Manager 4.1 on a Windows 2K Server box, but it is not a domain controller.
Our phones are also on their own vlan, so I don't see any cause for alarm.
Are there any gotcha's I should be aware of?
Thanks in advance.
Solved! Go to Solution.
03-24-2008 05:27 PM
I have done this in the past with a Callmanager 4.1(3) integrated with AD as well as Unity using the same AD. I had no adverse effects. There were no changes required in CCM or Unity.
Hope this helps. If so, please rate the post.
Brandon
03-24-2008 05:27 PM
Brandon
03-25-2008 08:07 AM
OK thank you. Yes, it was pretty straight forward. I'm a noob here, so I'm trying to keep the mistakes to a minimum...
