Community Member
Raising Domain Functional Level
I need to raise our Domain functional level to 2003, but my boss is concerned how this may affect our phone sytem.
We are running Call Manager 4.1 on a Windows 2K Server box, but it is not a domain controller.
Our phones are also on their own vlan, so I don't see any cause for alarm.
Are there any gotcha's I should be aware of?
Thanks in advance.
1 ACCEPTED SOLUTION
VIP Purple
Re: Raising Domain Functional Level
I have done this in the past with a Callmanager 4.1(3) integrated with AD as well as Unity using the same AD. I had no adverse effects. There were no changes required in CCM or Unity.
Hope this helps. If so, please rate the post.
Brandon
VIP Purple
Brandon
Community Member
OK thank you. Yes, it was pretty straight forward. I'm a noob here, so I'm trying to keep the mistakes to a minimum...
238
