Community Member
ramifications of using Veeam on a running CUCM virtual instance
Hello all, I know the documentation says that 3rd party backup utilities are unsupported, but are there any consequences to running it when I have 0 utilization? Would I break anything?
1 REPLY
VIP Super Bronze
The reason it isn't supported is there is no mechanism for the backup agent to force Informix into a consistent state before taking the snapshot. The call volume is irrelevent; it's the database that matters. This is why those backup products have agents for things like Exchange and SQL: it forces a sync to disk of all outstanding transactions. Since you lack root access (and presumably an Informix agent) you're out of luck.
Please remember to rate helpful responses and identify helpful or correct answers.
1056
