06-11-2007 10:40 PM - edited 03-14-2019 10:00 PM
I have handful of Ip phones which register/deregister w/ the ff. logs;
Can anyone help me how to attend this issue?
06/02/2007 02:01:57.779 CCM|StationInit: TCPPid = [2.100.132.2033317]Socket Broken. DeviceName=VGC15c647a98e15,IPAddr=192.168.0.1, Port=0x0, Device Controller=[2,118,1361389]|<CLID::StandAloneCluster><NID::x.x.x.x><CT::2,100,132,2033317.1><IP::><DEV::>
06/02/2007 02:01:57.779 CCM|StationInit: TCPPid = [2.100.132.2033316]Socket Broken. DeviceName=VGC15c647a98e09,IPAddr=192.168.0.2, Port=0x0, Device Controller=[2,118,1361394]|<CLID::StandAloneCluster><NID::x.x.x.x><CT::2,100,132,2033316.1><IP::><DEV::>
06-12-2007 02:44 AM
Please upgrade the phones to latest image.
06-12-2007 04:42 PM
thanks for replying...
I know this is a dump question but I don't know how...
How can I upgrade only 1 Phone? just for testing! I already download the firmware & got a TFTP software but cannot "put" the file on the phone.It says "the receiver block it".
I connect the phone (set the TFTP server ip to the pc that have the file)...is this correct?
thanks,
06-12-2007 05:56 PM
download the bin/sbin files and place in TFTPPath folder in CM. Then restart TFTP service. Under the phone you want to upgrade, under device config page, specify the name of the new firmware and click update, reset. Only this phone should now upgrade firmware.
Sankar
PS: please remember to rate posts!
06-12-2007 06:03 PM
thanks.
How about If I use a pc w/ tftp not the CM tftp service? will that be possible?
also in the device config of the Phone? where & how can I specify the name?
06-13-2007 04:02 PM
I was able to investigate more...
I think its a network issue. Can someone tell me whats the meaning of this?
tnx
Cisco6500#sho ip bgp neighbors y.y.y.y
BGP neighbor is y.y.y.y, remote AS 7474, external link
BGP version 4, remote router ID x.x.x.x
BGP state = Established, up for 2w0d
Last read 00:00:00, hold time is 10, keepalive interval is 3 seconds
Configured hold time is 10, keepalive interval is 3 seconds
Neighbor capabilities:
Route refresh: advertised and received(new)
Address family IPv4 Unicast: advertised and received
Message statistics:
InQ depth is 0
OutQ depth is 0
Sent Rcvd
Opens: 17 16
Notifications: 10 1
Updates: 59 120
Keepalives: 8620426 7759216
Route Refresh: 0 0
Total: 8620641 7759353
Default minimum time between advertisement runs is 30 seconds
For address family: IPv4 Unicast
BGP table version 445, neighbor version 445
Index 2, Offset 0, Mask 0x4
2 update-group member
Sent Rcvd
Prefix activity: ---- ----
Prefixes Current: 11 11 (Consumes 528 bytes)
Prefixes Total: 47 31
Implicit Withdraw: 16 0
Explicit Withdraw: 20 20
Used as bestpath: n/a 11
Used as multipath: n/a 0
Outbound Inbound
Local Policy Denied Prefixes: -------- -------
Total: 0 0
Number of NLRIs in the update sent: max 12, min 0
Connections established 16; dropped 15
Last reset 2w0d, due to BGP Notification sent, hold time expired
Connection state is ESTAB, I/O status: 1, unread input bytes: 0
06-13-2007 04:09 PM
Your BGP appears stable. Be assured, if there were connectivity problems between phones and CCM, you would notice because of voice drops during calls.
You can use any tftp server to upgrade phones.
06-13-2007 04:15 PM
actually I already noticed it cause all my phone drops last June 2 thats why I am investigating it.All the phones reboots but came back again. I don't want it to happen again...any method to troubleshoot?
what could they mean?
this is another switch:but same issue:
BGP state = Established, up for 6d13h
Below is the time I took the BGP status
3750#sh clock
15:21:41.323 UTC Fri Jun 8 2007
So the BGP has been establishing since 6 day and 13 hours ago, it is shown the BGP state was down on 2 of June.
3750#sh ip bgp nei y.y.y.y
many thanks.
06-13-2007 04:52 PM
If you had a connectivity problem on that specific time, you know already why the phones deregistered. However, phones should never reboot for lack of connectivity to CCM, just show "registering", then possibly reacquire ip address, etc, but never really reboot like in a software crash.
06-13-2007 05:09 PM
Opps, sorry for the confussion, the phone deregister/register not reboot. So Its really a network connectivity problem. Any more idea how to troubleshoot it...
your a greathelp p.bevilacqua...
thanks
